- Joined
- Apr 23, 2019
- Messages
- 1,213
- Points
- 113
In this editorial, Brent Justice recaps the AMD COMPUTEX announcements and gives his opinion on where NAVI and Ryzen are headed for the gaming enthusiast.
I wonder if performance on Zen2 will be as significantly affected by memory speed as Zen and Zen+? I hope that gets tested out once these are available for review.
I'm actually doing some testing on that with existing Ryzen 2000 series CPU's.
That would make for a great review, I'm interested in the results
That's actually the plan. This is something I wanted to investigate in detail, but never did. It's been my observation that over the years, Intel's CPU's have craved bandwidth and that tighter timings made little impact to performance on Intel platforms. AMD has been somewhat opposite to Intel in this regard. That is, its CPU's are less effected by bandwidth but tighter timings had a sometimes substantial impact. Obviously, we know Skylake and newer Intel CPU's do benefit from RAM speeds over 3000MHz, the same as Ryzen does. but where is the point of diminishing returns, and at which point does latency come into the picture?
While I was doing the first motherboard review for this site, I tested Threadripper and switched out my DDR4 3000MHz modules with tighter timings for DDR4 3600MHz modules with ****ty timings. I actually lost performance in some tests running at DDR4 3200MHz or even higher speeds. That's what prompted me to look deeper into the issue. So I've got a Ryzen 2700X on the bench and an Intel Core i5 9600K system for comparison. I'm going to use the lowest latency RAM I've got and compare it against the highest bandwidth RAM I've got and see what happens in various applications, benchmarks and games.
It will be interesting to see what effect this has in different tests and I want to revisit the topic with the Ryzen 3000 series when we get one.
Can't say I've seen much of anything on this in a while. Corsair did a quick PR video several years ago, but with a new uarch in Zen, it's time to revisit that and see what's up.
... So I've got a Ryzen 2700X on the bench and an Intel Core i5 9600K system for comparison. I'm going to use the lowest latency RAM I've got and compare it against the highest bandwidth RAM I've got and see what happens in various applications, benchmarks and games.
