- Joined
- May 28, 2019
- Messages
- 8,083
- Points
- 113
I know it's probably a sin to post about a pre-built rig but on sale this really looks like a decent buy for someone just starting out and wanting solid 1080p/1440p performance levels and still having options to expand upon later.
Presently has a promo code for Wolfenstein Youngblood as well.
BrandABS Computer TechnologiesSeriesMage HModelALI262
Form FactorMid TowerUsageConsumer
ProcessorIntel Core i7-9700K 3.60 GHz
Processor Main Features64 bit 8-Core Processor
Cache Per Processor12 MB L3 Cache
Memory16 GB DDR4 2666 MHz
Storage240 GB SSD + 1 TB HDD 7200 RPM
GraphicsNVIDIA GeForce RTX 2080 8 GB
Power Supply600W 80 Plus Gold
CaseDEEPCOOL MATREXX 55 ADD-RGB ATX Mid-Tower Case (3 x 120 mm ADD-RGB Fans)
Operating SystemWindows 10 Home 64-bit
Special FeaturesLiquid Cooling 120 mmMotherboard
ChipsetIntel Z370CPU
CPU TypeIntel Core i7 9th Gen
CPU Speed9700K (3.60 GHz)
L3 Cache Per CPU12 MBCPU Main Features64 bit 8-Core Processor
GPU/VGA TypeNVIDIA GeForce RTX 2080Video Memory8 GB GDDR6Virtual Reality ReadyYesMemory
Memory Capacity16 GB DDR4
Memory SpeedDDR4 2666Memory Spec8 GB x 2
SSD240 GBHDD1 TB
HDD RPM7200rpm
Optical Drive-None
Front Panel Ports
Front USB2 x USB 2.0
1 x USB 3.0Front Audio Ports2
Back Panel Ports
PS/21 x PS/2 keyboard/mouse port
1 x HDMI 2.0b
1 x USB Type-C
3 x DisplayPort 1.4
Rear USB4 x USB 3.1 Gen 1 Type-A (blue)
2 x USB 2.0RJ451 portRear Audio Ports3 x HD Audio Jacks: Line in / Front Speaker / Microphone
Expansion
PCI Slots (Available/Total)1 x PCIe 3.0/2.0 x16 (x16, x8/x4+x4) *
1 x PCIe 3.0/2.0 x16 (max at x4 mode)
* PCIEX16_1 slot supports up to 3 Intel PCIe NVME SSDs via a Hyper M.2 X16 series Card.**
** Hyper M.2 X16 series card sold separately. Install a Hyper M.2 X16 series card and enable this card under 4 x PCI Express 3.0/2.0 x1 slots
Mouse
Mouse TypeUSB MouseKeyboard
Keyboard TypeUSB KeyboardDimensions & Weight
Dimensions (H x W x D)18.90" x 8.27" x 17.32"
Are you a human?
www.newegg.com
SSD240 GBHDD1 TB
HDD RPM7200rpm
Optical Drive-None
Front Panel Ports
Back Panel Ports
1 x HDMI 2.0b
1 x USB Type-C
3 x DisplayPort 1.4
Expansion
Mouse
