be quiet! Announces Shadow Rock 3 190 W TDP CPU Cooler with Asymmetrical Design
Tsing
The FPS Review
Staff member
Joined
May 6, 2019
Messages
12,595
Points
113
Image: be quiet!
be quiet! has announced the availability of its latest mid-tier CPU cooler, the Shadow Rock 3. It boasts a cooling performance of 190 W TDP – a 10 W improvement over its Shadow Rock 2 predecessor, as well as a novel design that improves compatibility with taller memory.
While larger CPU coolers have a knack for blocking RAM slots, that’s not an issue with the Shadow Rock 3 and its asymmetrical construction, which comprises five angled heat pipes that shift the cooler to the side, providing ample room for most types of memory. These 6 mm nickel-plated pipes utilize Heat pipe DIrect Touch (HDT) technology to ensure maximum heat transfer between the cooler and CPU...
Continue reading...
So are you guys going to be testing this one?
I do have their PR Boffins' business card and was drinking whiskey with them in their suite at CES....
In progress to have a new cooling test bench up and running. Thermaltake Core P5 case has been acquired and the Intel 10980XE should make its way over here to complete the setup....
