- Joined
- May 6, 2019
- Messages
- 12,182
- Points
- 113
Image: Lian Li
Lian Li has launched the UNI FAN SL120. These are fans that feature a unique, modular interlocking system, which allows users to couple up to 16 fans together (under one controller) with a few simple actions. A special cable module with pin-to-pin contact points also means less wiring to worry about. Oh, and it can even sync up to 32 LEDs per fan for RGB goodness.
Original Press Release:
LIAN LI Industrial Co. Ltd., a leading manufacturer of aluminum chassis and PC accessories, announces the UNI FAN SL120, an innovative approach to reducing cables by interlocking and daisy-chaining the fans. Designed as 120mm high static pressure PWM fans with addressable RGB LEDs, the UNI FAN SL120 has a newly patented quick-connect daisy-chaining style system that simplifies cable management and mounting efforts...
Continue reading...
