Lian Li Launches O11 Air Mini PC Case with Modular Design and Extreme Airflow
Tsing
The FPS Review
Staff member
Joined
May 6, 2019
Messages
12,595
Points
113
Image: Lian Li
Lian Li has launched the O11 Air Mini, a new PC case with a small footprint and modular design for ATX, M-ATX or ITX motherboards.
Some of the O11 Air Mini’s key features include airflow-focused front, top, and side mesh panels that are complemented by two 140 mm PWM front fans and one 120 mm rear PWM fan, a modular back panel that enables compatibility with ATX, M-ATX, or ITX motherboards, and the ability to fit up to ten 120 mm fans with support for up to 280 mm AIOs and CPU tower coolers of up to 170 mm tall. ATX PSUs are also supported in the O11 Air Mini despite its smaller size.
The O11 AIR MINI will be available at an MSRP of $109.99 (USA)/$99.99 (global) for the black version and $119.99 (USA)/$109.99 (global) for the white version. An optional vertical GPU back panel will also be available for better display of graphics cards...
Continue reading...
I'd have called it the O11 AIR FAT
How is this mini, in any way?
