Light Wings: be quiet! Launches Its First Quiet Fans with ARGB Lighting
Tsing
The FPS Review
Staff member
Joined
May 6, 2019
Messages
12,595
Points
113
be quiet! has launched its first quiet fans with ARGB lighting for enthusiasts who desire something beyond the the quiet performance and sleek design that the manufacturer is known for. Available in 120/140 mm PWM and PWM High-Speed models, be quiet!’s new Light Wings fans feature an LED ring at the inlet and another narrow LED ring at the outlet, both of which are equipped with up to 20 individually addressable LEDs. They also include a diffuser for spreading the light in both directions.
From be quiet!:
Light Wings fans are available in two different versions. The PWM model, equipped with seven fan blades and a rotational speed up to 1.700 rpm (120 mm) or 1.500 rpm (140 mm) is ideally suited as a case fan thanks to its low operating noise level. The PWM high-speed model with nine fan blades and up to 2.500 rpm (120 mm) or 2.200 rpm (140 mm) is optimized for...
Continue reading...
'Addressible'
There are at least two types of controllable RGB, with ARGB allowing for the control of 'nodes' in the RGB 'loop', when the respective software cooperates.
