MSI Recalling Some MAG CORELIQUID 240R/360R AIO Coolers for Sediment Buildup
Tsing
The FPS Review
Staff member
Joined
May 6, 2019
Messages
12,595
Points
113
Image: MSI
Are you experiencing less than stellar cooling performance with your MAG CORELIQUID 240R and/or 360R liquid coolers? You are certainly not the only one, as MSI has initiated a recall program for these models after discovering that some of them may produce sediment, causing blockages that result in abnormal heat dissipation and high CPU temperatures even at idle. Users can determine whether they’re eligible for a swap by entering their product’s serial number in the link below.
Image: MSI
MSI MAG CORELIQUID 240R / 360R Product Announcement...
Continue reading...
Seen it here first
Greg Salazar did a video on fixing a PC with one of these AIO's and ended up taking it apart at the end and you can see the build up that accumulated over time.
