Snowy
Slightly less n00b
- Joined
- Jul 6, 2019
- Messages
- 113
- Points
- 28
Hi
My wife and I were talking about Hogwarts Legacy last night when she said (to my astonishment), "maybe you should build me a gaming computer". Wow. Okay. Absolutely!
She likes the idea of having the computer in our living room, tucked away in our entertainment console. This necessitates the build should be relatively small. The current cabinent that's available is about 13" deep, and 15" wide. It currently has a shelf in the middle so the height right now is about 10", but could go up to 17" if I remove the shelf and have something stand vertically.
I'd like to reuse components I already have if possible, but otherwise I need help selecting components that will
A) be relatively inexpensive
B) fit within a small form factor
C) relatively cool / not power hungry
Here's what I currently have from a previous build:
Case:
PSU:
Mobo: ASUS Prime X370-PRO AM4
CPU: AMD Ryzen 7 1700X
GPU:
SDD: (I have a spare around here somewhere)
RAM: CORSAIR Vengeance 16GB (2 x 8GB) DDR4 2666
As you can see, I need most components
I would consider an upgrade to the CPU if I can keep the motherboard.
Lastly, this will be plugged into our 55" LG C2 OLED 4K TV.
Since my wife isn't an avid gamer (seriously, she will probably only play Harry Potter and maybe Portal or some other Co-OP game) I'm thinking something built around 1080p should be fine and we can use FSR / RSR to make up the difference.
Thank you for your help!
Snowy
Case:
PSU:
GPU:
Snowy
