Thermaltake Launches White TOUGHRAM XG RGB DDR4 Memory
Tsing
The FPS Review
Staff member
Joined
May 6, 2019
Messages
12,595
Points
113
Image: Thermaltake
Thermaltake has launched new memory kits for enthusiasts who have distanced themselves from the traditional black setup.
Comprising eight kits with memory sizes ranging from 16 GB to 64 GB and speeds ranging from 3,600 MHz to 4,600 MHz, Thermaltake’s new series of TOUGHRAM XG RGB DDR4 memory features a white-colored chassis and cooling components complemented by an X-shaped light bar with 16 addressable LEDs. Other highlights include a 10-layer PCB with 2 oz. copper inner layer, tightly screened ICs, an aluminum heat spreader, and limited lifetime warranty.
From Thermaltake’s press release:
Being compatible with the latest AMD and Intel motherboards, the White TOUGHRAM XG RGB series has been through rigorous tests to select tightly-screened ICs, designed with a ten-layer PCB, constructed with 10μ gold...
Continue reading...
Naming fail.
That doesn't look tough. It looks fruity.
Should be called FruityRAM.
Yeah it should have been DDR5 at least that one is tough to get.
Maybe they make them out of the same stuff that they make unbreakable combs. That's some tough stuff.
I dont know why but I'm amused they have the Sandia inspired thermaltake cooler in the background.
