- Joined
- May 6, 2019
- Messages
- 11,677
- Points
- 83
USB-C will soon be capable of charging gaming laptops and other power-hungry devices without the need for separate barrel jacks and power bricks. As revealed by the USB-IF’s latest revisions to the connector standard (Release 2.1), USB-C’s power delivery specification is getting boosted from 100 watts to 240 watts, which is more than enough to power and charge the majority of mobile devices and peripherals on the market. The specification will be accompanied by new “Extended Power Range” cables that must support up to 5 Amps and 50 Volts.
With the change, you can also expect a new look for lower-power cables, called Standard Power Range. “For USB Power Delivery, each cable assembly is...
Continue reading...
