Stoly
FPS Regular
- Joined
- Sep 18, 2020
- Messages
- 1,565
- Points
- 113
So a few days ago I noticed that my work laptop which I use mostly at home, is having a weird wifi issue
If I disconnect the laptop from the AC outlet, it will loose wifi (even on a full charge), it will show as its connected but you can't surf or use the network at all, for example Facebook will show the network is not connected. Plug it back in and in starts surfing again within seconds. Also, restarting the laptop while disconnected, will solve the issue. If I disable/enable wifi the issue persists.
Any ideas?
Any ideas?
