- Joined
- May 6, 2019
- Messages
- 3,113
- Points
- 113
Same here, I don't NEED 16C/32T. Heck, I barely even need 8C/16T. The selling point when it comes to the 3950x to me is that it has higher boost clocks and higher binned chiplets. I want to get as much clock speed as I possibly can. Hopefully with decent cooling and a motherboard with good VRM's that means PBO + Auto-OC will make 4.9Ghz possible with lightly threaded applications.
I wouldn't bet on a Ryzen 9 3950X reaching 4.9GHz in lightly or single threaded applications. While PBO+200MHz offset is certainly possible, I rarely saw those speeds. In my tests, I generally still didn't break 4.5GHz very often. PBO and the offset isn't guaranteed to hit those clocks. Its based on an algorithm that requires conditions to be right to boost that high. I rarely saw the 4.6GHz boost clocks as is.
