EKWB Announces Magnitude sTRX4 Water Blocks for AMD Ryzen Threadripper Processors
Moderator
Staff member
Joined
May 28, 2019
Messages
8,876
Points
113
Image: EKWB
EKWB has announced a new water block for AMD Ryzen Threadripper processors called the Magnitude sTRX4. It uses a patent-pending technology called TDC (Targeted Die Cooling) with a jet plate insert that focuses the coolant over all 8 chiplets in parallel. Tops are available in nickel-plated brass, plexi, and acetal, with optional accents in nickel, black, red, and more. It has two industry-standard G1/4-inch (BSPP) ports spaced 29 mm apart. The Magnitude is available with or without D-RGB. The D-RGB versions feature 44 individually addressable diodes that are concealed between the accent and top. Prices range from $269.99 to $319.91 for the water block, and $35.99 for the accent...
Continue reading...
