New BOINC Project: Beacon@home
Skillz
FPS Regular
Staff member
AT Refugee
Joined
Jun 4, 2019
Messages
1,872
Reaction score
1,772
This project runs 5 applications. All of the applications are NCI, so you can run them on any host without it stealing resources from other projects.
1. A radiation monitor that currently works on the GQ-GMC 300 series detectors. This app is disabled for new accounts by default. If you have a host with one of these sensors then you'll need to enable this app for that host. The detectors location will be plotted on a global map, but instead of a precise location on the map it'll be placed within a 17km hexagon of the general area. So no one will be able to pin point your exact location. You will just need to provide your postal code so it can chart the area on the map.
I doubt it will work with other detectors, but if you have other detectors then let me know and I'll work on getting them supported if you're willing to help with it.
2 - 4. These are all similar apps based off the Goofxgrid@home NCI project. Goofyx had the source code of these apps on github, which hadn't been updated in ~9 years. So I took them, done some minor work on them and here they are. I did reach out to him, but I have yet to receive a reply. They were posted on Github under a GPL 3.0 license. If anyone has any contact information or knows how to reach him; please do.
All apps currently work on x86 Windows/Linux and ARM Linux (Raspberry Pi). I do not have a Mac to compile on or test, so Mac is sitting out until I obtain the hardware.
