- Joined
- May 28, 2019
- Messages
- 8,893
- Points
- 113
Image: NZXT
NZXT has announced matte-white versions of its Kraken series AIO RGB coolers. These are expected to be available in October. Prices for the Kraken X-3 series are $$169.99 (X53 RGB 240 mm), $189.99 (X63 RGB 280 mm), and $229.99 (X73 RGB 360 mm). The premium Z-3 series is priced at $269.99 (Z53 RGB 240 mm), $279.99 (Z63 RGB 280 mm), and $309.99 (Z73 RGB 360 mm). All feature NZXT’s CAM monitoring software, allowing users to customize lighting and check system information. The LCD display on the copper block can also be customized. The aluminum radiators are connected via rubber tubing in nylon mesh...
Continue reading...
