Phanteks Announces T30-120 Ultimate Fan
Moderator
Staff member
Joined
May 28, 2019
Messages
8,888
Points
113
Image: Phanteks
Phanteks has announced the T30-120 Ultimate Fan. It features 30mm thick glass fiber reinforced liquid crystal polymer blades, a SUNON motor, and industrial-level components. The motor is a 3-phase design with a Dual VAPO bearing that uses magnetic levitation for better performance and sound. It can be cranked up to 3,000 RPM or down to 1,200 rpm for quieter running. The blades use an aerofoil design for increased static pressure with 0.5 mm clearance for decreased turbulence. It comes with a six-year warranty and is available in single ($29.99) or triple ($84.99) packs...
Continue reading...
These are 30mm thick instead of 25mm. These could be great rad fans. Not sure about case fans, unles you have filters and enough space.
