Zarathustra
Cloudless
- Joined
- Jun 19, 2019
- Messages
- 4,410
- Reaction score
- 4,756
I strongly suspect that they aren't, considering they are laser etched glass.Yea the real issue is if they are actually re writeable or not.
But if the media winds up being cheap enough maybe that doesn't matter? Just toss and replace when you consume all the space. I mean, 500TB is quite a lot of space. Maybe you even use a fraction of it, and virtually erase old data by marking that portion of the glass used, and once all of the space is consumed move on to the next glass disk?
Heck, you could even combine this method with a method that uses multiple smaller glass squares all side by side. The laser shifts between them, but not too far to add too much latency. In firmware you set it up such that they are filled in order, oldest to newest. You have a feeder that can add glass squares when needed. Once only one glass square is left, the remaining data on the full glass square that has had the most data deleted is transferred to the new square. That old square is the purged, and a new glass square is added from the feeder.
Could be a cool way of doing it.
