Very weird laptop trackpad issue.
Stoly
FPS Regular
Joined
Sep 18, 2020
Messages
1,943
Reaction score
1,444
So, I have a HP 240G8 from work.
I don't actually use it that much at work, since I have a desktop there, so I use it when at home or visiting clients.
One of my coworkers uses the same laptop and told me the trackpad was moving erratically, he never used the trackpad before, but since he forgot his mouse at home, he was using it. So, I tried it and it behaved erratically, mostly with slow movements, the pointer jumped here and there. For kicks I tried mine and the same thing happened, another coworker with the same laptop also the same issue. Too much of a coincidence. a hardware defect maybe?
Well, it turns out our desks top is glass, so when I placed the laptop on a wooden or plastic surface, the problem got away.
Weird to say the least.
So it happened on glass but not on wood... glass is a ever so slightly better insulator in some cases so maybe the case was grounding through the desk and without it it was causing issue with the track pad and static buildup causing bad sensor readings... but wow that's specific.
I also tried it on the glass kitchen table and also exhibits the issue.
I've heard and had this happen with optical mouse on glass tops, but a trackpad aka touchpad on a laptop. There is no optical sensor. This is very strange indeed.
I've had it happen on two laptops so far, and it seems to happen a lot based on the research I last did. Best summary I could find is that it was a grounding issue. Never resolved it.
That leads to perhaps a ground is not attached to the track pad that can somehow work through probably touch when a wooden desk is present as opposed to glass??
But wow.. still.. you can see an example with those electric touch ball things that activate inert gasses to light up like lightening.
I could totally believe that. A lot of trackpads are capacitance based, and if you don't have a solid chassis ground on the laptop (very very few do), any amount of static will wreck havoc. Glass is notorious for building up static charge too, and it doesn't help that a lot of trackpad surfaces are also glass.
One of my coworkers uses the same laptop and told me the trackpad was moving erratically. He had never really used it before, but since he forgot his mouse at home, he gave it a try. The pointer was jumping around, especially during slow movements. I tried mine and noticed the same issue, and another coworker with the same laptop reported it too. I’m wondering if Techyest UK has any information about similar laptop issues. Three identical laptops showing the same behavior seems like more than a coincidence. Could it be a hardware defect or a driver issue?
My HP laptop apparently has a Synaptics touch pad. I have had many more issues with this touch pad than other laptops I have owned. The problems are random zooming of the the screen when my fingers are close to, but not touching the touchpad. I also get the right mouse click pop-up window when not touching the touch pad. The "solution" was was to turn off much of the touch pads functionality.
I have a cheap Lenovo with a trackpad that acts similarly, I can barely use it on a good day.
Thing is, it's not even consistent, most of the time it works fine, but others the pointer just jumps everywhere. Only on a glass surface.
So not a fan of track/touch pads, glass or otherwise. From laptops to surface pro's, and including my gaming laptop that I'm very much happy with, they are all over the map with issues to the point I'm more amazed when they do work with near perfect accuracy. I know that's not an answer to the question but just thought I'd throw my 2 cents in.
Always been a big fan of the pad on the Macbooks, no one else seems to get it quite right. But yeah, can't like play a game with it or anything - not the same thing as a mouse at all. Plenty good for productivity though.
The stupid clit mouse on IBM/Lenovo always threw me for a loop.
What gets me is that people swear by that thing... I'm like.. WTF HOW is this useful?!
That and I can never find the **** thing when I need to... ;)
That is really weird and new to me as well, and never have guessed a glass desk could cause something like that. I guess the trackpad is more sensitive to the surface or electrical interference than we’d expect.
