After a little episode where I had to spend over 20 minutes doing something as simple as plugging out an ethernet cable, plugging in another one, then plugging the old one back in, it's starting to get obvious that my current case does not fit my current room situation.
It is also very annoying that my mouse cable is very restricted in where it can go due to the case being so far away from my desk.
Thus, having an ITX board, it would probably be relevant to make use of that fact.
I am not exactly looking for a tiny little box, as my GPU is a massive abomination I can't do much about - and we all know what GPUs are like these days.
However, with my current case dimensions being 535 mm x 235 mm x 550 mm (W x H x D) [a flipped-around Enthoo Pro] - a solid half of the **** case is empty space.
Any ideas for something a bit smaller with some less oodly-doodly airflow paths?
www.techpowerup.com
something like this seems to fit the bill
SilverStone SUGO 14 Review - High Compatibility with No Compromise
The SilverStone Sugo 14 is not just another rehashed SFF cube. It has been designed to offer the best of all worlds when it comes to an ITX chassis. The Sugo 14 has amazing hardware support. You may install a long triple-slot graphics card, a large tower cooler, an ATX PSU, and 240 mm radiator.
