Elf_Boy
Quasi-regular
- Joined
- Nov 9, 2019
- Messages
- 343
- Points
- 43
See sig for system specs.
Best I can run my ram is 5200. Trying at 6000+ will result in a failed boot that goes to defaults and 58/5600 will lock the system resulting in needing a cmos reset.
The ram is rated for 6400. Even at 2 sticks it will not exceed 5200 and even at 1 it wont do 6400.
Could be a silicone lottery thing and whenever the 9000 series comes out I get a better memory controller.
Running bios 1813 (11.1.23)
With ddr4 I could play with voltage and on my Ryzen 1800x needed to up it a few .1's to get the ram working at full speed. With the voltage being regulated on dimm with ddr5 I want to be a bit captious.
Would increasing the timings help (how and what to use?)
Not horrible - get some nice benchmarks as is, just hoping to run everything as purchased.
YES I know these particular dimms are not on the officially tested list.
Thank you all for any input or help.
-EB
-EB
