- Joined
- Apr 23, 2019
- Messages
- 1,366
- Points
- 113
On our test bench today is the MSI MEG X570 GODLIKE Motherboard for review. Tune in to see how we like this high rolling board!
another nice review .. will you be running your 3900x on your X470 anytime soon for comparison sake ...or throwing a 3700x into the mix when doing future mobo reviews?
what about a chipset review/comparison? ... or have you already covered that? x370 vs x470 vs x570 .. or a320 vs x570 .. etc .. all with same cpu/memoryGenerally speaking, I only use one processor for motherboard reviews. Essentially, the benchmark numbers aren't really important. The point of them is to ensure the motherboard is performing correctly, and that no issues are encountered during the various workloads. In other words, it isn't about the processor. I typically use whatever the highest end CPU is that I have on hand at any given time for the reviews as they punish the VRM's more than less demanding CPU's.
I will be looking at the 3700X, but that will be for a CPU review, not a motherboard review.
I have a good memory, it's just awful short ...![]()
Thanks for the response .. good to know and great for those of us using X370 and up chipsetsNo, I have not. Essentially, the chipset has nothing to do with performance. It makes little sense to run the same benchmarks on X370, X470 and X570. Once AMD and Intel moved the memory controller into the CPU, the motherboard platform effectively became all about features. There is about 10 years (or more) worth of data to validate this. You see a gamut of results all within 1-3% across an entire generation of motherboards we would review for a specific socket or chipset. This is basically an acceptable margin of error for the tests. Again, there really isn't a point to benchmarking each platform with the same CPU. It won't yield anything we don't already know.
Users today may find a PCIe 4.0 option available in their pre-X570 motherboards. However, users should expect this option to be disabled when final retail BIOSes are released to implement full performance and stability for new 3rd Gen Ryzen processors.
As pre-X570 motherboards were not designed with PCIe 4.0 in mind, their designs may be incapable of running PCIe 4.0 signaling with the requisite stability and performance. To ensure a reliable and consistent experience in the field, PCIe 4.0 will not be an option ultimately available to pre-X570 motherboards. Users may continue with a beta BIOS if they desire, but performance and stability cannot be guaranteed.
I don't know why motherboard manufacturers turned it on in the first place. However, I can bet that AMD thought it was a bad idea for most motherboards and is turning it off in AGESA code permanently so that it doesn't cut into X570 sales, nor cause potential problems on X470.
