- Joined
- Jun 4, 2019
- Messages
- 1,879
- Reaction score
- 1,781
The solder won't melt?
I'll let you think about that for a while before responding.
Call it a fuseThe solder won't melt?
nice idea. lets mandate a fuse in every GPU power cable for 5080 & above class GPUsCall it a fuse
So you solder again every time it melts? Fun job!I'll let you think about that for a while before responding.
Or just solder it right for the first time?So you solder again every time it melts? Fun job!
Right, but if it could be ignored before but not now, that means this connector is worse with no safety margin.Right but because testers ignored them then.. doesnt mean you can ignore them now.
Undersizing your power supply is a choice. With the cable you have no choice. If I could replace the connector with four PCIE power cords I would, but I can't. You shouldn't need to buy a $150 gizmo to prevent your $10000 GPU from catching fire.Thats like running a 5090 and high end system with multiple drives on a 800 watt chinesium power supply that is 80 plus bronze but nowhere to be found on the registry.. it might work... or you might need the fire department.
Soldering would fix the resistance issue, right, but what about the voltage imbalance between pins, it wouldn't fix that would it? I would think some kind of hardware would be needed on the PCB to regulate the voltage per-pin, IIRC NVIDIA removed this hardware function.
If you use enough solder it willSoldering would fix the resistance issue, right, but what about the voltage imbalance between pins, it wouldn't fix that would it?
Discussion about the merit of the connector not withstandingRight, but if it could be ignored before but not now, that means this connector is worse with no safety margin.
I think there is already enough data to draw a conclusion what more can they add? I believe they just didn't expect it to happen to them, well like everyone else.Discussion about the merit of the connector not withstanding
The point was that the influencer/author/whatever you want to call them had access to all the tools, and was under the pretense of testing the card - but ignored a key tool in their toolbox. Had they been watching everything - I dunno if you could have prevented it, but you could have got some pretty interesting data if nothing else.
I have to admit, while I don't fault HU for the card failing, but they did miss a good opportunity. The conspiracy theory is they intentionally ignored it hoping for flames, because smoke and fire = more clicks. I don't necessarily believe that, but ... they did post the video for clicks.
So, and sorry if I missed this in the thread, what if there's a poor connection at the PSU side?
The test equipment should not affect the peformance - so the testing is still “real world”you employ all the tools the average person doesn't have access to then the testing isn't very real world
Quantum mechanics says measurement always affects the resultThe test equipment should not affect the peformance - so the testing is still “real world”
And if it does affect performance that’s worthy of a story all by itself
I mean yes... that is very true. Any monitoring introduces impedance even if negligible.Quantum mechanics says measurement always affects the result![]()
And even negligible impedance can significantly affect load balance.I mean yes... that is very true. Any monitoring introduces impedance even if negligible.
And that affects FPS by…And even negligible impedance can significantly affect load balance.
This wasn't about FPS, you said they could've collected valuable data on the meltdown if they used wireview or a similar tool. But the mere inclusion of the tool might have changed the outcome.And that affects FPS by…
Well, had they done the testing that way, then it blew up later on without the test equipment - that would also be news-worthy. And even if it didn't - still would be very interesting to know, particularly since this issue is very much out there.This wasn't about FPS, you said they could've collected valuable data on the meltdown if they used wireview or a similar tool. But the mere inclusion of the tool might have changed the outcome.
