- Joined
- Apr 23, 2019
- Messages
- 1,279
- Points
- 113
We've got a brand new review of the Cooler Master Hyper 212 Evo cooler. This is an oldie but goodie, check out if it can keep up in 2019.
Good to see you guys back in Action. I just stumbled on your site (VERY HAPPY). Like Space Ranger posted above, it would be nice to see some comparisons with other coolers. I am guessing that as you add more reviews, you will include the old review numbers for comparison?
How did the Evo compare to the Wraith Prism that comes with the 2700X for instance?
As a thought comparing it to a stock AMD Wrath Prism Cooler on the Ryzen 3's could help others see the differences upgrading from the provided box cooler.
Good review. Only thing I would like to see on it is if an additional fan with a push/pull config would be worthwhile to stabalizing your system even under prime95/futuremark with the overclock.
Just curious. Does anyone have any stories to tell with setting up a 2nd fan for the push/pull configuration? I've always wondered how effective it would be.
Good review. I will always have a soft spot in my heart for these things. The 212+ was my first "high end" cooler back in the day and it ran my Phenom X6 1090 at 3.9 for a long time. Even used it on my FX 8150 when I "upgraded" to that and it handled it to 4.2 Ghz if I remember right but ran out of juice passed that.
I'm currently using an old (ordered in 2010) Hyper 212 Plus with my 1700X since the CPU didn't come with a cooler. Luckily I have a microcenter nearby so the AM4 X-bracket only cost me a couple of bucks instead of "free" plus $15 shipping- if you go with this cooler on AM4, maybe check amazon and ebay, etc to see if you can get the bracket for less than $15 direct. I needed to install some rubber washers on the back of the motherboard to keep the cooler seated tightly, but it's been working just fine for general gaming.
I'll probably keep this cooler going until I upgrade to one of the 3000 CPUs at which point I'll either use the bundled cooler or look into a higher-end air cooler like something from Noctua.
Looking forward to more cooler reviews!
