Denpepe
FPS Junkie
- Joined
- Aug 5, 2019
- Messages
- 2,326
- Reaction score
- 1,649
This one has some modularity https://www.bequiet.com/en/case/dark-base/771
You had better luck than me with getting parts. Ordered some new fans only for Newegg to let them sit in their warehouse for two days before pick up, and then another set had UPS have a sorting issue which delayed them a day. Was planning on moving things over tomorrow, but now I'll be into next week to build. Looking forward to some pics of your build though.Case and card came in yesterday and I was able to get everything(mostly) done last night. I'll post some pics later.
I think it was the universe finally giving me a break in 2022. I also do all the supply ordering for my job and it's been a total $h!tstorm since the new year but to be honest I started seeing things getting wonky 6-months before COVID broke out due to the pissing contests of various world leaders combined with whatever crisis were already happening at the time. I feel for you and I hope it all works out.You had better luck than me with getting parts.
How so?One note... I don't know how much it matters. but for that front mounted 360 rad... you want to reverse it and have the connections at the bottom of the rad rather than the top because it's better for the health of your pump/radiator setup. Since it's the GPU rad I think you have the cable length to do it.
Was literally about to post that video.Here is a better explanation:
Supposedly air bubbles with eventually gather and cause issues for the pump or something.GD videos - anyone have the TLDR?
I made it about 5 minutes before I had to stop - him stuttering and never getting to the point, I couldn't take another 25 minutes of him dragging it out to boost his ad revenue.
But if there's a legit reason I'd like to know what it is.
I might. I do normally trust Steve and the guys but I feel there are mixed messages between him and EVGA. If I interpret EVGA as saying don't put the hoses below the card that goes against what he's saying but then again their image is the entire radiator and that doesn't quite apply here either.One note... I don't know how much it matters. but for that front mounted 360 rad... you want to reverse it and have the connections at the bottom of the rad rather than the top because it's better for the health of your pump/radiator setup. Since it's the GPU rad I think you have the cable length to do it.
Not that I think it would hurt the cooling performance just impact the life of the pump.
Plus side you could hide some of the tubing behind the power supply Rad and clean the look up a little to boot.
What EVGA is saying is do NOT mount the rad below the card. Mount the Rad ABOVE the card... which is correct for Horizontal mount. What you will want to do is have the connections to the radiator at the bottom of the rad with the card height below the top of the rad since you are vertically mounting the Rad. The whole issue with orientation is to not have air trapped in the pump but in the Rad as they are not made to be air free.I might. I do normally trust Steve and the guys but I feel there are mixed messages between him and EVGA. If I interpret EVGA as saying don't put the hoses below the card that goes against what he's saying but then again their image is the entire radiator and that doesn't quite apply here either.
For sure. The other problem though is the ideal way would be to disconnect the hoses to properly pipe them under. I'm pretty sure if I try to bend them into that space in front of the rad they'll be crimped, and restrict the flow to a major degree which becomes another problem. I suppose an alternative would be to use metal cutters to cut more out there so that wouldn't be an issue.What EVGA is saying is do NOT mount the rad below the card. Mount the Rad ABOVE the card... which is correct for Horizontal mount. What you will want to do is have the connections to the radiator at the bottom of the rad with the card height below the top of the rad.
I don't know your space or physical restraints within the case but....For sure. The other problem though is the ideal way would be to disconnect the hoses to properly pipe them under. I'm pretty sure if I try to bend them into that space in front of the rad they'll be crimped, and restrict the flow to a major degree which becomes another problem. I suppose an alternative would be to use metal cutters to cut more out there so that wouldn't be an issue.
I had thought but I'd have to disconnect the lines to do it. I mean, at that point I'd have to bleed it and make sure there are no air bubbles and possible refill it and I don't even know what they used or what to get.I don't know your space or physical restraints within the case but....
If you look at the crappy red lines I added...
Yea no see my edit. I was dumb. Dremel really is the only way here and that kinda sucks. Unless they have a shorter shroud available they would swap out with you. You SHOULD be fine because you are so far from the top of the loop though based on Steve's logic.I had thought but I'd have to disconnect the lines to do it. I mean, at that point I'd have to bleed it and make sure there are no air bubbles and possible refill it and I don't even know what they used or what to get.
No worries. I do agree with you and Steve. I'm looking into buying metal cutting shears. Spending $20 on that isn't a problem and I've got the strength to do it. The air vent holes could actually work to my advantage.Yea no see my edit. I was dumb. Dremel really is the only way here and that kinda sucks. Unless they have a shorter shroud available they would swap out with you. You SHOULD be fine because you are so far from the top of the loop though based on Steve's logic.
