Corsair K70 RGB Pro mechanical keyboard...
Nice thanks for sharing. I updated mine just fine and that is a relief. My motherboard doesn't have any onboard USB ports less than 5 gig. so a slower one would be hard to find! I'm using the cable that came with the keyboard too. Interesting.
I mean technically these ARE refurbs...
The noise doesn't bother me though I came from a K70 with Cherry MX blues.
Are you sure there's not at least 1 older/slower USB port on the motherboard, for stuff like mice/keyboards? But moot point anyway if it worked for you no issues.
Yeah there should at least be one USB 2.0 header inside
Maybe the mobo had a built in hub?
Oh yea there are a couple USB 2.0 headers and 2 USB 3.0 headers and one USB C header 3.2 I believe.
Heads up, saw this thing is $110 off for $49.99 now on Corsair's site.
yeah wrist rest and o-rings really made this an awesome keyboard for me. except for the stupid volume wheel, I hate it so much.
Hey, just a heads up about an issue I discovered and thought I'd share. Got a prompt from iCUE to update keyboard firmware, but it kept failing. While looking for help with another issue, I came across the Telstra customer service number and some useful troubleshooting discussions. The instructions said to bypass USB hubs and connect directly to the PC. Tried that and a different USB-C cable, but neither worked. On a whim, I plugged it into a slower USB 2.0 port (black) instead of the USB 3.0 (blue) one I usually use, and the firmware updated successfully. Strange!
Also worth noting I got some o-rings off amazon for five bucks and it made a world of difference in the noise factor. Also dampens the feel a little bc they keys aren't bottoming out as hard. Also also.... I'd swear it makes the keys less sensitive since there is a resistance now.... or maybe I'm just getting used to the thing finally.
That makes sense, especially coming from a K70 with Cherry MX Blues. You're probably already used to the extra noise! Good to hear the update went smoothly. And you're right, refurbished units can sometimes have little quirks, but if everything is working properly and the noise isn't an issue, I'd say you're in good shape.
