Endgame
Semi-regular
- Joined
- May 30, 2020
- Messages
- 890
- Points
- 93
lol, I have no idea if anyone sells a waterblock for a ddc, as if you wanted water cooled pumps you would usually run a D5.Wouldn't the big brain move be watercooling the pumps?
Hehe, maybe some dayI love how those look on the side of the rack! If you ever need more cooling, you could rotate the rack and put 2 more on the other side![]()
A question for you - you’re planning multiple pumps and reservoirs but I’m not 100% sure where you are planning on mounting them. Have you considered using another 3U case and putting most / all the pumps in that case? If you’re going for DDC pumps, that would likely give you plenty of space to mount them and also to arrange for dedicated airflow to cool them.
Well, it took all night, but I got the rack rearranged, holes drilled for the second radiator, mounting brackets mounted, and radiators test fitted.
I had almost forgotten how much of a pain in the *** cage nuts can be.
Almost.
I wonder if that's enough radiator capacity. Might need to add some more?
Anyway, this took all night, and we are getting a whole lot of snow tonight, so I am going to be shoveling tomorrow.
Probably won't make much more progress on the project this weekend.
The only pump I’ve ever burned out is a DDC. I had one in a swiftech bayrez (version 1 of this: http://www.swiftech.com/MaelstromV2.aspx) and had it tucked in an area with basically no airflow and no heatsink. I chalked it up to user error, and moved on, but if I ever did a DDC again, I’d have it actively cooled with a big HSHehe, maybe some day
The two pumps used for the radiators will hang right underneath the reservoirs, which will hang on the side of the radiators.
The plan originally was to get some sort of plastic "hobby box" to install the PSU and Aquaero devices in, bolt that to the side of the case next to the radiators, and then mount the three additional pumps for the systems on top of it.
That worked in my head before I started measuring, but with the size of these radiators, that is obviously not going to fit. There is no space left next to the radiators (unless I go all the way down to the floor underneath them, but I don't want to do that).
The current revised plan in my head is to buy a large-ish PVC junction box from the electrical aisle at Home Depot. Something like this:
I could then use the C-channel metal bars left over from my initial failed plans (in previous posts) and attach those across the rear rails of the rack, and bolt this box to those bars.
It then attach the three remaining pumps to the lid of this thing. I think with the DDC's exposed to open air, they won't need much in the way of airflow over them to keep them cool, especially with all of the air moving near those radiators.
I'll of course have to cut some holes for ventilation, but I think it will wind up being pretty good.
As an added bonus, I could use actual electrical liquid-tight flexible conduit to route all of my wiring (power, fan speed control, pump speed control, etc.) for a nice clean look that aids in cable management.
At least that is my current thinking until I have a better idea.
So, I have always used D5 pumps, and by design they cool themselves with the fluid that passes through them, dumping it into the loop, but with like 22-25W each, we are talking like 125W if they are all at full speed. That's a not insignificant amount of added heat load to the loop.
Yes, these radiators are large and overkill, but I still want as much as possible of that capacity going towards cooling my components, not towards cooling my pumps.
There is little to no downside just having pumps that are air cooled avoiding dumping heat into the loop, and that's the reason for going with some DDC's.
DDC's have much lower flow rates than D5's though, so I figured, I'll use DDC's where flow rate is not likely to be critical (radiators and workstation) and keep D5's for where I really care about flow rate (CPU and GPU blocks for the game machine)
I’ve got an Ehiem 1250 that’s been working fine since 2003 in various loops, and several d5s, all of which still run. Only had the one bayrez ddc fail.I have a decades old D5 that I've been running in a pond off a solar panel for years.
Have you tried any ham radio supply stores? They are the last big DIY electronics market that I’m aware ofI'm having a surprisingly difficult time finding these parts from anywhere a normal human being (without a purchasing department, or a need for reels of 10's of thousands of parts) can purchase these without serious ripoff pricing.
Some seller on amazon has kits of them with 5 connectors and exactly 20 terminals for like $7 each, which is a crazy price considering these cost pennies a piece. (also, having only exactly the right amount of terminals is a bad idea, as I know I will break some as this is the first time I crimp these)
We used to have this electronics store in the greater Boston area named "You-Do-It Electronics". They were amazing. Think Radioshack back in the day, but like 100 times the size.
Unfortunately they closed their store a few months back. They had been operating since the 40's. It was a huge loss. I could probably have found these parts there at non-ripoff prices.
I think the problem is almost no one DIY's electronics anymore, and that is a crying shame. We live in a "buy a finished device, then throw it out and buy another" era.
If anyone has any recommendation on sourcing of these parts in 100 or less quantities at non-rip off prices that sell to consumers, I'd appreciate it.
I wouldn't be surprised if Microcenter could help (NOPE search for part shows motherboards)... what about Granger? if you know the parts you need.Have you tried any ham radio supply stores? They are the last big DIY electronics market that I’m aware of
Digikey and Mouser both used to allow private sales in smaller quantitiesI'm having a surprisingly difficult time finding these parts from anywhere a normal human being (without a purchasing department, or a need for reels of 10's of thousands of parts) can purchase these without serious ripoff pricing.
They will sell in the quantity you need.
The fan bracket has two boards on the back of it with headers for the fans.I thought the radiator had built in fan headers for easy wiring. Why aren't you using that?
I think that would work. I was thinking a decent pair of nail clippers.
2.) Do I have the wrong terminals? (I mean, they are the right one, but maybe I got the ones for automated assembly, not for manual crimping?
