- Joined
- May 6, 2019
- Messages
- 3,308
- Points
- 113
I agree with the post above me but for an answers sake I’ve seen people say 1.35 and some say up to 1.4. Personally I wanted to be a far below 1.35 as possible.
I've had to use upwards of 1.4v on some motherboards. However, for the 3900X, 1.35v or so usually suffices.
Question for Dan. Will I have any issues moving my Raid 1 array? It is not a boot drive.
If you are switching between Intel and AMD based chipsets and you are using the motherboards RAID OROM for the RAID configuration, you absolutely will run into problems. It may pick it up as a foreign array and allow you to import it, but I wouldn't bet on it. That said, you might be able to retain data on the array when recreating it. Some configurations allow that. Intel supports this on their side, but I haven't done it on the AMD side.
If you have an existing RAID array from an AMD based system you'll be fine.
